Coast 1310 front drive shaft vs. custom shaft locally.
Ahhh, Canadian money. That makes sense.
Still confused about the front arms though. Everything I have read says that double cardans need different angles (pinion pointed at the tcase instead of parallel to the tcase output) and then play with the front caster/pinion to find the sweet spot between flighty and vibes.
Ohhh, with the lift, the pinion is already pointed up. Gotcha...
Eventually I catch on.
JK-Forum Founder
Since your caster is already low and the pinion is already pointed up a bit, you may not need the arms. Sound right?
Thanks WOL. So just to get this straight. I don't need either set of arms? I just don't understand how my new shaft wont fail like the stock one did without getting the geometry back to "stock".
And thanks for the link. Crappy thing is my torque wrench starts at 20 ft/lbs and the bolts on the transfer case end are supposed to be set to 15 ft/lbs.
So after all the extra reading I've been doing and after being told I shouldn't need the arms I still am left wondering why my DS has gone bad (if I don't need arms to correct the geometry) and what it is in the DS that goes "bad" and causes the drive line vibrations?
Anyone?
Anyone?
JK-Forum Founder
Yep, that is where I was confusing myself. (and correct me again if this is incorrect WOL, it's just the way I am thinking of it) After the lift, the caster is low, causing flighty handling. So we add adjustable arms to raise the caster (which lowers the pinion). This is where most posts I see start from. Caster is already corrected, which lowered the pinion, so when adding a double cardan DS, they would want to adjust the pinion angle again - which lowers the caster and gets into the caster vs vibe situation.
installing a set of adjustable control arms to increase the amount of positive caster you have (dropping the pinion even more) will help improve your handling after installing a tall lift and when running big tires but, the increased angle placed on the pinion and drive shaft joint will cause binding - in other words, vibrations. reducing the amount of positive caster you have (setting your pinion to be in line with your drive shaft) will help eliminate this bind and cause your vibrations to go away but, it will make your jeep feel super flighty. this is the balance we all struggle with or, at least for those who don't have locking hubs.
JK-Forum Founder
Anyone?
Anyone?
