Coast 1310 DS with stock height?
Will a Coast 1310 aftermarket front DS still fit/work if you remove the lift and return the vehicle to stock height?
Maybe 3-6 but I can't be sure. Got it here:
Coast JK 1310 Front Drive Shaft
Not 100% sure if it's the same one as listed here which says 3-6" because the part numbers are not the same.
Coast Driveline & Gear
It's not installed (still in the box), so I can't say for sure how much is showing. I may just call Coast to see.
