Coast 1310 Driveshaft Maintenance
I thought of that as well looking at the pictures on Project-JK - it would make getting to the tcase bolts a lot easier with the skid out of the way. Where exactly do you jack the front up at? I presume you're just using the jack to get the tires up just a little and not using jack stands?
JK-Forum Founder
you can lift your jeep up from the axle and set it back down on stands. you just want it so that you can rotate your wheels. more times than not, i just do this with the jeep on the ground and roll my jeep forward or back as needed to do the same thing. either way will work.
There is a needle fitting zerk, kinda looks like a belly button. You need a needle adapter for your grease gun end, the small kind that just snaps into your reg. One
Got the needle adapter - just not sure where exactly the needle fitting zerk is located.
JK-Forum Founder
honestly, it's just as easy to bend the double cardan open, smear some grease on the ball and then work it in. as you work it in, it'll give you a chance to get a physical feel for how it's working.
JK-Forum Founder
Thanks Eddie. I'll try and go that route - didn't get a chance to get that part done last Sunday because it started getting really hot and the driveway concrete starts getting a little toasty warm when the temps are in triple digits . May start on it early this coming Sunday.
Also, I'd emailed Coast to check before I started the thread here, and their response was this - so, does this mean that putting the grease on the center ball wouldn't do anything if they are sealed . I'll still probably drop the driveshaft and put the grease in there for good measure and when I take it down, will check to see if I see any zerk in there.
Im sorry wayoflife i could not resist.. thats what she said!!
but in all reality I have not done this with my coast driveshaft and i have had no problems i have been greasing the zerk on the shaft every other oil change to keep up with it i might pull it off the jeep this weekend and make sure everything still looks good. Thanks for all the great information everybody
