clutch engaging next to none
hey guys, i'm hoping I can get some help with this.
I've been having trouble shifting in my 6speed and this is my second slave cylinder replacement on it.
I'm positive that all the air is out because the pedal feels great..
the problem...
when the jeep is off shifting through gears is simple..as soon as the jeep is running it's a different story.
every gear is very difficult to get into, sometimes if it's even possible.
i'm noticing while getting into first..if I have the clutch pedal to the ground it wants to start rolling forward before it can really click into first. once i find the sweet spot on the pedal the jeep will get into gear..but sometimes there is no sweet spot.
so, now i'm in first gear..sitting still with the clutch to the floor, the jeep wants to roll and or stall as if it's really not engaging.
by the way, this all occurs in every gear
does anyone have any ideas what is going on?
the throwout bearing is brand new and like I said, this is the second slave for this transmission. (the first one I did, it was leaking at the boot about 2months into it.)
all ideas are greatly appreciated!
the problem...
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
So if the Jeep is off and you put into 1st gear, push the clutch in and start the Jeep, what happens?
Then when you let the clutch out (still in 1st gear). What happens?
Sent from my iPhone using Tapatalk while wrenching on my Jeep.
Starting in first gear the jeep wants to start rolling forward or stall out. When I let the clutch out it begins to roll like normal. I notice when I drive it's very difficult to shift. Sometimes I find a weird sweet spot on the pedal and it shifts easier.. (Sweet spot... When I push the pedal to the floor to shift I'm stuck in the gear I was in..slightly let off the pedal and it comes out of whatever gear and easily falls into the next desired gear)
OK so the clutch is still making contact with the flywheel even with the clutch pedal depressed all the way to the floor.
The clutch is hydraulic so there are no adjustments...just need to make sure it is bled properly. They can be a real bear to bleed. What was your process for bleeding?
OK so the clutch is still making contact with the flywheel even with the clutch pedal depressed all the way to the floor. The clutch is hydraulic so there are no adjustments...just need to make sure it is bled properly. They can be a real bear to bleed. What was your process for bleeding?
It's been doing it. Pulled the transmission out, put a new Throwout bearing on making sure it seated properly and put it all back together. Started it up and the problem was never fixed.
Only other things that come to mind are....you have wrong clutch disk, clutch disk is installed backwards, pressure plate is warped or the pilot bearing/bushing is binding up.
Former Vendor
Have you sank the Jeep in any mud holes? If you did was the clutch compressed at all?
Good suggestion about the clutch disc being installed backwards not allowing the clutch to disengage.
