Clicking From Underneath
Old 07-10-2008 | 08:08 AM
KnuckleHead's Avatar
Default Clicking From Underneath
Just when driving and going over little cracks/bumps in the road, I hear a click/clicking noise coming from underneath my JK on the front passenger side...coming from some place between the door and my front bumper. I don't know exactly what it is...I do know it's not my disconnects at all.
Can anyone just give me a hint or list as to what they think the clicking noise might be? If I just have an idea where to look, then maybe I can find and solve the problem.
So please, ideas???
(2" BB w/ 33" tires and Mopar front/rear Bumpers)
Old 07-10-2008 | 08:15 AM
Bodo's Avatar
Hard to say but it might be a good idea to check your trackbar mounting bolts, swaybar links and anything else you see for tightness.
Old 07-10-2008 | 08:18 AM
07JKX's Avatar
did you use shock adapters?? if so, check the nut on the top of the front shocks... make sure its tight...
if no shock adapters, check it anyways b/c thats where my noise came from
Old 07-10-2008 | 08:22 AM
wayoflife's Avatar
JK-Forum Founder
what makes you so sure that it's not your discos? clicking of the nature you have described are typically caused by shifting of suspension components. swaybar links are a major culprit as well as loose shocks, track bar, control arms (especially if they are adjustable) and things like that.
Old 07-10-2008 | 08:26 AM
Joe Lightfoot's Avatar
Sponsoring Vendor
Off Road Evolution Rep
x2 on the shock adapters I had the same problem..
Old 07-10-2008 | 08:37 AM
It's not my discos because I already checked and tightened them...I didn't even think about my shocks. I'll check that out ASAP when I get off work. My control arms are stock, but I'll check the nuts/bolts on them too.
Thanks!
Keep the ideas and suggestions coming. Just list anything. Right now I need ideas of where/what the problem may be.
Old 07-10-2008 | 09:45 AM
undertow119's Avatar
Stupid question, but are you sure it's not a stone or a nail (or something) stuck in your tire tread?
Aside from that......who knows.
Old 07-10-2008 | 02:33 PM
hyatt147's Avatar
i have the same thing but mine is what seems to be on the driver side
Old 07-10-2008 | 03:54 PM
JulietKilo's Avatar
Everytime someone describe this sound it sounds like you have thrown a clip on the dog ear of your front axles. The cap then comes off the u-joints then rounds out the axle ears. Check to see if youhave this problem.
Old 07-10-2008 | 04:42 PM
hyatt147's Avatar
my problem started right when my jeep came off the lift from doing the susp. lift...so u think it would have happened that fast?
