Chrysler Voided My Engine Warranty for Using their Mopar Cold Air Intake.
I have my favorite Cash picture for an avatar for a reason.....
Possible cause. Just like water, air will follow the path of least resistance.
With the pre-filter over the stock filter, is it possible, that the added restriction caused the air to be pulled in through a gap, crack, or some other opening in your intake tube between filter and the throttle body.
It is unlikely that BOTH the filters failed. If they were installed and properly seated then the debris had to be pulled in downstream of the filter
If that's so, maybe the dealer didn't properly install the intake or the intake tube failed in some sort of way.
Just a thought.
Just a thought.
Just a thought.
Just a thought.
Since Redneck Jeep is no longer a participant on this forum, let me parrot what he used to say years ago: High performance air filters are high performance because they let more air through. They do that by also letting more fine particles through. They have no business on a Jeep that is taken into dusty situations (Mojave Trail)--they are a street-only mod (he actually didn't even like them for that).
I have a friend who is most insistent that I am wrong about this. He insists that K&N filters are the best thing going. But, in this case, I trust Redneck Jeep, with four decades experiences as a mechanic, more than my friend, who knows more about his Corvette than his Jeep.
Get a Wix or similar quality filter in the OEM housing. Avoid CAIs and other "high performance" filters. Sorry for OP that you are just further evidence of what Redneck Jeep used to say repeatedly on this forum years ago.
As for buying an OEM manufacturer part and having the connected parts covered: I've never heard of such a thing. Read those exclusions and limitations in the warranty carefully. They virtually all exclude related and incidental damage.
Also, it's extremely easy to over oil the oil-type filters and I've seen a lot of "contamination" down the induction system from excess filter oil. I'd also bet most clean them too often as well. They'll go a long while before cleaning's needed and with each session comes more excess oil. Not to imply any of this is related to the OP, but food for thought.
