Choosing an on-board air system..
Am looking at the various options, gearing up for beach season.
I am just getting started and as yet have only narrowed it down based on my budget and the complexity level of the install. Now it's time to thin out the contenders.
Can someone please help me understand Duty Cycle? What it is, how it impacts performance and why I should pay attention to it.
My use will be primarily for airing up after a beach excursion.
Don't waste your money on onboard air then if mostly for beach stuff. Just buy a VIAIR 400 so you can still fill your 35s.
Other brands on market That I would look into
ARB
Smittybilt
This is just a site I used to get you example links
/www.4wheelparts.com/Winches-and-Winch-Accessories/Smittybilt-Air-Compressors.aspx?t_c=18&t_s=190&t_pt=100437&t_pl=5 822
://www.4wheelparts.com/parts/viair-compressor/viair-portable-compressors.aspx I'd get the 400 if you have 35s
://www.4wheelparts.com/Towing/ARB-Air-Compressor.aspx?t_c=67&t_s=3&t_pt=4644&t_pl=393
You will have to copy from www on
ARB
Smittybilt
The VIAIR link I sent you will give you enough examples of what each will do. Also going portable will only cost you max off $200. Onboard you have to buy mounting hardware and all the other bs, oh and install time...
You can also save some green by getting a cheap portable pump from the local parts store and hard wiring it to your battery. It may take a little longer than the Vlair and other pumps that are expensive, but only cost $60 and work fine.
Thanks all.. As I usually do, I realized a few facts I should have added to make this more relevant to my situation...
I read/watched Woods Torture Test on the Viair units sold by Dominion Offroad and man, those are impressive. I could have those either portable or hard installed. The ARB units seem cost effective but they are what led me to the question about duty cycle.. one was [gulp] 10% duty cycle.. Skip that one. The other I found was 30%. Better but not perfect. There is a Viair Constant Duty unit, which might be overkill in the other direction given how much use it will get. On a recovery vehicle it might be perfect, though now that I think about it my family would probably appreciate not having to wait for the compressor to cool down.
I wouldn't mind having a storage tank. Air horns would be cool too.![Rock](https://www.jk-forum.com/forums/images/smilies/rock.gif)
But referring again to Woods Torture test, the value of the tank is limited.. according to Woods.. " If I fill the [2 gallon] tank to 145 PSI and turn the compressor off, the tank will fill one tire from 9 PSI to 18 PSI." Meh... other than for air horns, I don't know that I see value in that, unless I am missing something which is entirely possible. Someone enlighten me.
There is a write-up on the forums here on how someone installed a Smitybilt unit behind the right rear tail light in the cubby that is otherwise unused space. Not sure how well it cools in there, but that is worth re-reading.
Thanks for the info on the duty cycle.. that was my initial question. Does your Viair 200 fill your 35's without shutting down? Is it a portable unit or can it be hard-installed as well?
Now, if I am understanding duty cycle correctly, it is measured at 100psi. So, with a unit that is rated 30% duty cycle at 100psi, should we expect it to stall for cool-down at all when operating at a much lower psi? Does simple math work here? If I am running at one third psi, can I expect three times the duty cycle efficiency? 90% duty cycle at 33psi?
I am curious if those units that are installed underhood need the hood to be open to run efficiently or if the hood can stay closed.. that would impact my decision for where to mount the air pickup if I go hard installed.
- If you didn't check already, I am on 33x12.5's
- Yes, primarily beach excursions so I am looking to air up four 33's from around 15 psi
- Installation.. no big deal. That's part of the fun!
- I have a 2 door, so there is trade off when adding a portable unit.. It's one more thing to carry. A hard install can use otherwise wasted space in the engine bay
- I have an el-cheapo portable.. I think it's a Central Machine from HF. It belongs in my wife's cross-over for emergency use only.
- My budget can accomodate $300 - $400 if needed.. Less is fine though.. there is no shortage of other mods I would like to do
Duty cycle is also a trade off with cfm output. A Viar 400 has only a 33% duty cycle but puts out almost twice as much air as a 450 with 100% duty cycle. My 400 will fill 33s from 15 to 30 psi in about 3 min per tire without shutting down.
It has an intake filter that you can attach a hose to so it intakes from the cab or anywhere outside the engine bay. I mounted it under the hood and ran a line with a chuck to the from bumper. Then ran a switch to the dash so I don't have to open the hood to air up. Works great for me.
Did you use the Dominion Offroad kit?
Where did you mount the remote filter/intake?
Originally Posted by MikekiM
That's good to know.. very good. Thanks
Originally Posted by GL08JK
I have an ARB on board air setup under the hood and I have to have my hood up to use it only because that is where the flexible air line connects to (under the hood). Once I am done airing up I unhook the airline and shut the hood. I am prety sure that if I had another place to connect my airline to it could be used with the hood down.
GL08JK
GL08JK
