Check engine light
At first i did it kind of slow and no codes or anything but when i did it faster i still didnt get any codes but the -done- showed up. maybe you are doing it to slow but i dont know much about it. Thanks everyone for the help. Hopefully i am good to go.
I am doing it pretty quickly. I read the write-up about pushing the key in so it does not catch on the stops. You turn it all the way to just short of starting, right? (2 clicks if the key was not pushed in)
stop at the last click before starting your jeep all the dash lights should illuminate and on the 3rd time stop and all the dash lights should be on and it should read where your mileage is
Location: Hangin in the sunshine state....staging forum..
P0882 -transmission control output circuit is used to supply power to the Power control module. transmission solenoid/pressure switch assembly and the PCM when in normal operating mode. The purpose of the trans output circuit is to allow the trans control system to turn off the power to the trans solenoid/TRS assembly in event that the trans should need to be placed into limp mode due to dtc.
time to visit the dealer
haha, oh well, need to go there anyway, having problem with a soft top latch and need and oil change.
