Check egine code related to exhaust leak?
Did some thread searching and possibly have already found an answer to my question but just wanted to ask it directly and hopefully get a straight answer....
Check engine light is on with a P0171 code which is fuel system too lean. In addition, I am more than positive I have ANOTHER exhaust manifold crack/leak. Is that more than likely the cause of the check engine light/code?
2007 JKU Sahara
2007 JKU Sahara
Here is the list of possible causes for P0171. Exhaust leak falls under Engine Mechanical, but it is very early in the troubleshooting procedure.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]RESTRICTED FUEL SUPPLY LINE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]FUEL PUMP INLET STRAINER PLUGGED
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]FUEL PUMP MODULE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 SIGNAL CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 RETURN CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]MAP SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]ECT SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]ENGINE MECHANICAL
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]FUEL FILTER/PRESSURE REGULATOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
