changing my lift and have questions
In the next month or so im goint to chang some parts of my lift and have a few questions
First. The lift on my jeep (its a 2013 2door) has a rough country 2 1/2 budget lift with a rear track bar reloction bracket.
Second. Im wanting to get rid of the pucks and put on metalcloack 2 in dual rate springs.
Third. Will there be any problems with this? And if so what will it be, thanks for the help.
If you have a rear drop bracket i would change it to a axle side TB bracket.
Caster correction ie brackets, front CA's (upper or lower) Front track bar (axle center)
Are you running shock extensions?
Are you just buying springs? Are you happy with the setup currently? What other parts did the current budget boost include? A typical 2" lift includes some form of front caster correction. Either adjustable front lower control arms or AEV correction brackets. A front adjustable track bar and longer shocks or shock extension brackets should also be added.
Also you will have a rake with those coils...so unless you have a lot of junk in the trunk you may want a 3/4" spacer up front.
I have the rear 3.5 MC coils and it sits level with the 4" Evo coils. I do have a 37" spare and steel JCR rear bumper as well.
Sent from my SM-N920T using JK-Forum
