Changed my Diff cover - oil problems (pics)
Up front I put in 1.5 quarts (FSM 1.35 quarts), and it was a tad too much. During the summer I got a little blow out of the breather tube.
x3 looks like you may have over filled......if you look at the above pic with the diff cover and line.....if you actually filled that diff up to the fill hole.....since the hole is above the axle shaft and seal it will leak alot.......do you have factory cover or after market cover?
I overfilled the front even more actually. So much that its coming out the breather. But not the seals.
If the problem is my axle seals, will the oil continuously leak at this spot, or will it only leak when there is pressure on the seals?
I guess my confusion is what to do now that I am at the correct oil levels...
Wash it off underneath, run it and see if it leaks.... or just see if it leaks on its own...or something else?
There is, of course another possibility. You may have found a "weak" axle seal. Synthetic oils tend to flow so much better than carbon based materials that they can very well make a leak "happen" where conventional carbon based oils would not.
Or does it just depend on how bad the seal is?
