Change oil from non synth to synthetic
#21
5-7k with synthetic? Doesn't seem worth it to switch. I change dino every 6k, 3k is way too early to change even dino oils imo unless you're really driving it hard.
#22
If your burning oil that's the best reason to change to synthetic. It doesn't burn off like Dino. Your oil burning will stop 100%. I put synthetic in my z turn mowers for that very reason. I would have to add a liter every 3 days but on synthetic I never have to add any !
#23
Under the same driving conditions (duty cycle), synthetics can go significantly longer between drains. It's a function of purity and add pack chemistry.
Mileage-based drain intervals without being backed up by UOA or at least OCIs are a shot in the dark. (for syn or conv oils)
#24
One of the bigger benefits of synthetic is at start up, especially in cold weather. Start up is when most wear happens.
#26
