to change differential gear oil!!!
I read this write up in project jk.com
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Maintenance Differential Fluid Change Write-Up
and I have question. to open drain nut? something i have 3/8" drive ratchet. also when I tight it should be 25 ft torque.
so.. do I have 3/8" torque wrench? i already have 1/2' torque wrench...
and why they use drive ratchet? if it need torque wrench anyway? I mean why they also don't use torque wrench to open drain nut
A ratchet driver is used instead of a torque wrench because its what is was designed for. A torque wrench is a calibrated tool, not a breaker bar.
Exactly.....DON'T use your torque wrench as a breaker bar, you should only use it to torque something after it has already been tightened up!
