centering difference springs/spacers
I am looking to do a winch and winch bumper on my TF BB. I have the spacer and another 3/4 spacer up front to level it out. Now I know the added weight will lower the front end so I am considering coils to even it out.
Right now, my front axle sits 1/4" to one side; so it is basically 1/8" off. It drives and handles fine for me. Since I have a "spaced lift" of 3.25 inches in the front, I am guessing that the springs will sit close to that mark.
My question is, would my amount of axle shift change if I added springs (vs. having spacers) IF the height is exactly the same? In other words, do springs cause the axles to shift any difference than spacers would?
Thanks
Thanks
Axle shift will be the same with spacers or springs, it all depends on height. After I added a winch, winch plate,2 skids and a compressor to my front end I lost about 1.25" I think 1.25", I'd have to recheck the measurements I took, but it was about that. The front end also felt very spongy after the weight was added.
Im extremely happy after I replaced the front spcers with springs. It sits level, handles better, and just over all feels more solid on and off road. I definitely recommend switching to HD coils.
Currently, I do not have an adjustable front trackbar; which is the main reason for asking. I want to avoid getting one right after I put the bumper, winch and coils in b/c I will not be able to afford to do everything.
