catalytics clogged or high altitude?
Dynotune is not going to help unless you change something major on your jeep. You need to get more air back into the engine, a tune is not going to give you more air.
Rob
Sent from my HTC Glacier using Tapatalk 2
Originally Posted by ronjenx
Yes. A '56 Beetle with sunroof.
Run 85, and welcome to high altitude. When I drive to the Lake of the Ozarks (600-700ft above sea level vs 5000ft) my car feels like i have slapped a supercharger on it, but I quickly adapt and stop noticing. Soon you won't notice. Forced induction (turbo/supercharger) is great at altitude because it isn't as effected by the thin air as normally aspirated engines.
Originally Posted by Ryan0260
Nice. A buddy of mine has that same motor in his dune buggy. It will fly. To the OP, out of curiousity does your motor use oil. If so, that is what is clogging up your catalytic converter
Originally Posted by spicoli
I run 85, no problem and saves money. Higher octane only gives you performance if you are running more advanced timing... Or if you find that you're getting knocking on 85, then maybe buy 87. The engines today have so many sensors that even if you were getting knocking, the timing would probably slow to compensate before you would even notice.
Originally Posted by DocFuller
***I was burning the often-seen quart per 1,000 miles... Switched to Amsoil 5w30 and replaced PCV/plugs and almost stopped the burn completely. Damage to cats might already be done***
