Catalytic converters
Old 03-18-2013, 01:57 PM
  #21
4wheels4life's Avatar
Originally Posted by shockwaveaz
An exhaust leak would throw the same code...or a bad oxygen sensor. Just don't want you to spend all that money if you don't need to. Did you check for leaks or test the voltage on the sensor? If it is your cats... You should just save and get the ripp headers since they come with cats.
Sent from my Galaxy Note 2
I have an multi meter just do not really know how to use it. If I know where to set the dials and what to look for I can do it just need to know. So how do you check the sensors?
Never mind I found out how to do it.
Old 03-18-2013, 03:23 PM
  #22
AtlJeepsTer's Avatar
Originally Posted by JKingAround
It's part number 3 and there's 4 on there two on each side of the Y and I found it for 600 with the return of the core at wholesalemoparparts.com Now I went with a free flow aftermarket but I can getaway with one the downstream one does not effect the computer. Depending where you live and how your states emission tests are whether that would work for you. Each cat has precious metals in them so that why the core is worth so much.
Now I'm relly lost...lol..number 3 is a Pipe Lock Nut and still can't find a part in Exhaust system area of the Chrysler Build sheets that has a quainty of 4 requirements. Yeah it's Platinum that's so valuable, they say worth about $1,620 an ounce....
Old 03-18-2013, 03:25 PM
  #23
JKingAround's Avatar
It's the pipe that looks like a Y all the cats are welded into that part
Number 3 do you see where the pipe flares out twice on each side.
Old 03-18-2013, 03:29 PM
  #24
Attachment 435459
Oh, so number one, which is sold as one part with all 4 included...
Old 03-18-2013, 03:37 PM
  #25
Ya it's sold as one part
Old 03-18-2013, 03:43 PM
  #26
This is from Wholesalemopar .com...the name you have above redirects to a Fl site with a different address....wholesaleoeparts.com/
[TABLE="align: center"]
[TR]
[TD="colspan: 5"][/TD]
[/TR]
[TR]
[TD] converter & pipe 3.8 LITER
[/TD]
[TD="align: right"]MSRP[/TD]
[TD="align: right"]Core ?[/TD]
[TD="align: right"]Online Price[/TD]
[/TR]
[TR]
[TD="align: right"]$975.00[/TD]
[TD="align: right"]$200.00[/TD]
[TD="align: right"]$707.85[/TD]
[/TR]
[/TABLE]
Old 03-18-2013, 03:47 PM
  #27
WeRmopar site:
Part: CONVERTER & PIPEclose
[TABLE]
[TR]
[TD="align: right"]Part Number:[/TD]
[TD] 52059930AH[/TD]
[/TR]
[TR]
[TD="align: right"]Drawing Ref. no.:[/TD]
[TD] 1[/TD]
[/TR]
[TR]
[TD="align: right"]Description:[/TD]
[TD] CONVERTER & PIPE[/TD]
[/TR]
[/TABLE]
List Price: $975
Our Price
$684.45
[TABLE]
[TR]
[TD="align: right"]Quantity for Cart:[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD="align: right"] Core Charge:[/TD]
[TD="align: right"] $200.00[/TD]
[/TR]
[/TABLE]
Old 03-18-2013, 03:51 PM
  #28
[TR]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
It was a phone price was six with some change. There out of Lakeland Fl.
Old 03-19-2013, 01:58 PM
  #29
Some more info on my cats. Used a infrared temp. gun on it today and here are my numbers. These numbers where taken at operating temp. running at 2000 rpm's and are listed as before and after in Fahrenheit . Drivers side main cat 733-636, second cat 404-393. Passenger side main cat 711-627, second cat 584-484, Numbers do not look good. Guess I really do need to get new cats Anybody have any thoughts as to these numbers.
Old 03-19-2013, 07:55 PM
  #30
Ya replace them looks like there clogged. If you can't afford to replace them right away. A temporary fix would be remove the upper O2 sensor and spray some sea foam in there use the green aerosol can. And revive the engine until it stops smoking. It will help for a little while but it's not a permanent fix.
Quick Reply: Catalytic converters
