Castor Issues?
#41
the best way to retain your caster and to lift your vehicle as high as you want is to bite the bullet, have the ends of your front axle tubes cut off (by a professional), adjust your pinion level to the angle required by the lift (and get the right kind of driveshaft...a double cardan joint at the t-case). After you take the measurements, have the same professional weld the ends of the axle tubes back in place. You can play with all the long arm/short arm/adjustable/non-adjustable things you want, but the ONLY way to make your Jeep handle as it was intended after you lift it is to have the front axle cut and re-welded. The rear diff can rotate in order to maintain correct pinion angle without such drastic measures, but you will need to get a different track bar to recenter it.
This is not opinion...it is a simple matter of geometry. Raising your pinion angle (which happens if you lift your Jeep even by two inches) CHANGES the caster angle (which affects your steering).
If you do not have the knuckles cut off and rewelded where they need to be, the best that you will be able to do is to get your Jeep "close" to a balance of ideal pinion angle and good handling. Some people opt to keep the pinion angle factory after a lift, which is great for handling, but even on a 2 inch lift or anything higher the factory pinion angle will adversely affect the life of your driveshaft, and it may vibrate. U-joints were made to operate at angles of around 3 degrees. A double cardan joint can take a much more aggressive angle, but they are designed to have the lower single u-joint (the one at the pinion flange on the diff) be close to zero.
The shame is that if Jeep had stayed with a real driveshaft and set up the caster ad pinion angle properly for that it would have been a lot better for the average lifted JK.
#42
ok thanks so im right in my way of thinking, Raising a car will Increase Pinion Angle Front & Rear, and because the pinion angle in non adjustable from Caster (unless you cut your tubes) your Caster will INCREASE with a Lift not decrease as RedneckJeep suggests.
The main reason for increasing Caster then is as i understand, fitting larger Diameter Tyres has an effect of decreasing Castor.
#43
correction
As you lift the Jeep then the top of the diff will rotate forward...which DECREASES caster. "Caster is the fore or aft slope of the steering axis. The steering axis is a line drawn through the upper and lower ball joints of the knuckle. Positive caster is when the bottom of the steering axis line is in front of the tire's contact patch. Zero caster is when the steering axis is at 0 degrees. Factory alignment specs for basically all vehicles call for a certain degree of positive caster. This ensures good stability, helps maintain straight-ahead direction and promotes steering wheel self-centering." The stock JK has NO provisions for caster angle realignment. Also to consider: "As the JK is raised, track bar angle increases and when lift height exceeds 2" bar length becomes an issue. Bar bind causes the chassis and axle to continuously "tug" against each other resulting in uneven ride height (side-to-side), chassis / frame misalignment and "roll and yaw". Front correction is accomplished via a new adjustable track bar. This route is preferred, as opposed to using a relocation bracket, since the bar's arc-of-travel must remain in-sync with the drag link's arc-of-travel or steering wheel "kick" will result." If you raise your Jeep even three inches, the axle will have shifted and will need to be shifted back over towards the passenger side by about 3/8″ in order to re-center it. The steering wheel also need sto be re-centered so as to not trick the system into activating the ESP/BAS.
Factory caster is around 4.2 (positive), and many folks see, to prefer even a little more with bigger tires (6ish). "As you move to larger and larger tire sizes you alter the caster due to the larger tire footprint. Large tires give you more positive caster. To compensate, you need a new caster setting to offset the larger tires. The following are just suggested starting points. Tire diameters will depend on air pressure and actual specs for the brand and model of tire.
37 in: 5 degrees
35 in: 5.5 degrees
33 in: 6 degrees
<33 in: Adjust to factory specs
Too low of a caster angle will generally result in your steering wheel not returning to center after you complete a turn. The short story is that if you do not cut the knuckles and align your pinion angle (which is MORE important than the caster in terms of vibration from the driveline and the possibility for catatrophic u-joint failure) after a lift, you may use adjustable arms to get the caster the way it was intended...BUT at 6 degrees the pinion is even more downward than it was at 4.2 (factory). If you run it like that, it will steer great (if you also recentered the wheel and relocated/adjusted the track bar to center), BUT count on vibration from your shaft and/or a greatly reduced u-joint life. If you do get it cut and rewelded by a shop that does this for a living, you get the best of both worlds...a lifted Jeep that not only handles like it was designed too but also that is dependable on the trail (and vibration free).
If you don't, you will spend zillions of hours on this and other forums trying to make sense of what everyone else did and what they settled for...but unless they did it the right way, there is no way to beat the geometry equations!
1. Increased driveline angles = vibration and u-joint failure
2. Decreased caster = your steering wheel doing its own thing (while your JK wanders all over the place)
3. Increased caster = increased driveline angle (unless you cut the knuckles and relocate them).
37 in: 5 degrees
35 in: 5.5 degrees
33 in: 6 degrees
#44
No more probs and RE BB
No, I have the twin tube ones.
Thanks for your advice RedneckJeep I'am just trying to learn as much as possible and the only way to do that is ask lots of questions. But your right I want to eliminate one variable at a time.
Anyone else have OME HD coils with no weight (bumpers) and feel like they feel every little bump in the road?
Want to sell my RE BB but have to get a few more posts before I can officially start a "For Sale" thread.
Thanks for everyone's help.
#45
#46
#47
I took RedneckJeeps' advice and crossed the tires...no more pull to the right. I also purchased the OME shocks (replaced my RE BB shocks) to go with the OME coils and wow, what a difference. The thing rides so much better with the matching suspension components.
