Castor Issues?
#31
i did not need to cut my bolt. i did have to temporarily move the exhaust out of the way. when i put the arms back on, i pushed the bolt through the other way (through the frame hole). it's much easier messing with the caster now. just make sure you have a good magnet puller just in case you drop in the bolt inside the frame.
#32
Yeah, I ended up cutting my bolt. It looked easier.
No, ever since I bought all five of my 32s I have been rotating them in a counter-clockwise fashion about every 5K to incorporate the spare and hopefully get more mileage. So this time my rear passenger went to my front passenger and so on.
#33
#34
Why do you think this would be the problem all of a sudden? I had a RE BB lift on it for about 20k miles before the OME lift and it never did this. One of the guys at the alignment shop said it was because my caster. My arms are the same length and I have about 5.5 on driver and 5 on passenger. Should I shorten them by one or two more turns to get about 6-7 degrees and maybe this will even things out? I am just afraid my pinion angle is too steep then with my stock driveshaft.
#35
#36
Also, ever since I put on the OME HD coils up front I seem to feel every bump a lot more. Kinda like bump steer, especially on the freeway when coming from an uneven bridge. I don't have any weight up front (bumper/winch) but I do have a 4dr. I am also running RE shocks from my RE BB that I previously had. Do you guys think its a weight issue, dampening issue, or other issue?
#37
No, I have the twin tube ones.
Thanks for your advice RedneckJeep I'am just trying to learn as much as possible and the only way to do that is ask lots of questions. But your right I want to eliminate one variable at a time.
Anyone else have OME HD coils with no weight (bumpers) and feel like they feel every little bump in the road?
#38
so what Actually happens by lifting you Jeep and keeping original control arms-
Wheel Base Shortens and Castor angle Increases (Pinion Decreases on Front & Rear). So Caster will naturally increase with say 3" lift.
The Uppers are shorter than Lowers therefore as you Lift the Axel Pivots.
Y/N?
The Rear Lower Control arms are Shorter than the Front Lower Control Arms so when you lift it will be the Rear C/A that will decrease Wheel Base more and should be made longer than the Front C/A to Correct Wheel Base, but everywhere i read people seem to Set the Front C/A longer than Std as Compared to the Rear, Why is that so?
Y/N?
#40
lift woes
the best way to retain your caster and to lift your vehicle as high as you want is to bite the bullet, have the ends of your front axle tubes cut off (by a professional), adjust your pinion level to the angle required by the lift (and get the right kind of driveshaft...a double cardan joint at the t-case). After you take the measurements, have the same professional weld the ends of the axle tubes back in place. You can play with all the long arm/short arm/adjustable/non-adjustable things you want, but the ONLY way to make your Jeep handle as it was intended after you lift it is to have the front axle cut and re-welded. The rear diff can rotate in order to maintain correct pinion angle without such drastic measures, but you will need to get a different track bar to recenter it.
This is not opinion...it is a simple matter of geometry. Raising your pinion angle (which happens if you lift your Jeep even by two inches) CHANGES the caster angle (which affects your steering).
If you do not have the knuckles cut off and rewelded where they need to be, the best that you will be able to do is to get your Jeep "close" to a balance of ideal pinion angle and good handling. Some people opt to keep the pinion angle factory after a lift, which is great for handling, but even on a 2 inch lift or anything higher the factory pinion angle will adversely affect the life of your driveshaft, and it may vibrate. U-joints were made to operate at angles of around 3 degrees. A double cardan joint can take a much more aggressive angle, but they are designed to have the lower single u-joint (the one at the pinion flange on the diff) be close to zero.
