castor?????
if you're setting your caster with adjustable upper arms, it's position won't change at all, it'll just rotate down. if you're doing it with lower arms, more caster will have the axle shift forward by a bit.
+4.2° is stock and there abouts is the bare minimum i would go with. if you do more, it'll make your jeep handle nicely at highway speeds and, if you're still running stock gears, vibe will most likely not be a problem. you only really start to see vibe issues when running 5.13's or higher.
