Caster, Steering, and Front Drive Shaft
I have a 4" Skyjacker lift with a caster angle of 5.8... My steering is still so flighty and my front drive shaft is tore up.. I was told maybe 4.5 would be better... I just want some ideas to get the steering tighter and what Front Drive Shaft I should go with next...
I am curious about replies too. I have the same lift. I've added adjustable front upper and lower control arms and keep my tire pressure at 25 psi. Mine is fine around town up to about 60 mph but still flighty on the highway at 70-75.
Good reply.. ummm.. yeah I was told the joints were in good shape... and the toe in is good... I haven't tried re-torquing anything.. I will have to do some research to see what the specs are but I will do that and see what happens... the biggest problem is just the steering wheel has close to about 3" of play in other direction before the wheels start moving.. and that's going down the road
Good reply.. ummm.. yeah I was told the joints were in good shape... and the toe in is good... I haven't tried re-torquing anything.. I will have to do some research to see what the specs are but I will do that and see what happens... the biggest problem is just the steering wheel has close to about 3" of play in other direction before the wheels start moving.. and that's going down the. road
I bought it with this set up and it has been like this since I bought it.. dealer says the steering box is fine.. also they said everything was tight.. if u could post the way the flip kit is supposed to look, I can compare.. they bushing are a little worn but are in decent shape..
