Caster and pinion newbie question
Installed 3 1/2 in standard RE lift on 08' JKU with BFG 33s
If I get adj control arms to correct castor what does that do to pinion?
Caster is at 2.5 currently, Jeep handles well, no wobble. Still occasionally set off ESP on cloverleaf turns despite post lift alignment from a trusted 4wd shop
I was already planning to change out the stock front DS if that matters.
