Caster / pinion angle
I have a 09 4dr JKU Sahara w/ a rubicon front axle and a 3 1/2" metalcloak lift. I am running 35" tires at 30 psi. I initially installed the lift to metalcloak specifications for upper and lower control arm lengths (which should have given about 5 deg caster). I also have had the front driveshaft replaced. This gave me somewhat flighty steering and a low rumble / vibration at 70mph. While I have lived with this for a while, I'm heading out to Ouray for some jeeping and would like to solve this before my 1200 mile drive. I just measured the angle of the front differential at the flat spot (with a hole) and measured 3.3 deg. I am assuming that this flat spot is parallel to the flange. I plan on adjusting the UCA's to achieve 6 deg on the differential flat spot.
I just wanted to confirm that I am on the right track here with my measurements. I haven't had an alignment done recently, and the tire wear is good and the jeep does not wander.
I woundn't assume anything. To be honest, even on a garage floor with zero slope per digital angle finder, I still found measurements at the pinion flange to be over 1* than the alignment machine read. If you're getting a "rumble" after the new DS, I'd lean more towards you have too much caster and it's jacking with the DC DS than too low caster. Just my opinion, but I'd get a reading from wherever you feel good about...as a baseline. Then, go get an actual alignment reading and make adjustments from your baseline. IE, just adjusted as the difference from your baseline reading in the garage by whatever you feel like you should adjust by off the actual spec.
The best way to adjust caster is to get an alignment check done, then keep track of how much you change it at home. (What Resharp001 said; condensed version.)
Regarding your vibration at 70mph, keep your speed below the point of vibration until you get it figured out.
This is what usually brings on a front T-Case explosion:
Lifted
Re-geared
Double cardan at the front of the t-case
Adapter on the t-case front flange, rater than the shorter replacement flange
More than a couple degrees from straight between front pinion and front drive shaft
Highway speed
Vibration (whether perceived or not)
Another factor is lack of lubrication in the front double cardan. This can cause the same result without any of the other factors.
Lifted
Re-geared
Highway speed
Lifted
Re-geared
Highway speed
Lifted
Re-geared
Highway speed
Think about this.....1* change in caster is a huge amount. Is your eyeball calibrated to the point of seeing 1*? I mean, when using a non-digital angle finder I can barely even read the 1* slashes. When using a digital angle finder on a pinion flange, depending on where you place it on the flange itself you'll get varying readings. My point just being that these aren't things easily seen by our eyes. It's great to use an angle finder at home if you know what the true reading off a machine is. I got a "lifetime" alignment at my local Firestone years ago. That $140 (at the time) has more than paid for itself. Down here you can usually roll in for an alignment and even if you opt to not have them make any changes (those places can only center the steering wheel and set toe) they will give you the print out. Now, nothing is free......I swear they take 90 minutes cuz they go over your entire car looking for anything that could be replaced or serviced and then suggest that to you.
If you do take it somewhere to dial it in, definitely double-check the torque on your control arm bolts and jam nuts. Here's food for thought Chris.......Every bit of money not spent on someone twisting your upper MC arms a rotation one direction or the other, is money that could be put towards a skid plate which would give you bit more peace of mind.
Well, I just got the alignment on the Jeep done. 3.8* LF and 4.0* RF. That gives me a starting measurement using a digital level on the diff. While the low angle (assuming 6* is optimal), would explain the "flightyness" of the steering, it doesn't explain the slight (or low) rumble that I hear/feel at 70mph. After re-doing the angle, I'm considering pulling the front driveshaft to see if that eliminates the problem. Do I need to pull the entire ds, or just disconnect at the diff and tie it up so it doesn't fall off?
Probably different with an offroad shop. The normal alignment shops usually charge additional fees to adjust control arms, and that 1) usually isn't worth the amount charged, and 2) means some dude working in a Firestone garage is messing with my suspension. Both things I like to avoid if possible. I guess I prefer to monkey with my own jeep.......that way if something happens or i forget to torque a bolt there's no one to blame but myself.
