Can't get front axle to lower enough to install front coils
#21
The torque values aren't crazy on those UCA's. I'm looking at mine now and don't see why a regular ratchet wouldn't work there. The sway bar link is slightly in the way but nothing impossible.
#22
you did a lot of unnecessary work for a 2in lift. The whole install should have only taken 4-5hr by yourself. I've done many lifts for our club members in my garage and have never had to loosen control arms for a lift under 2.5in. But since you did be sure to torque everything down and double check every bolt you touched then go back and re-torque after 100 miles or so.
#23
Yep, it's that sway bar link getting in the way. I don't currently have a 21mm ratchet wrench, and a 21 mm socket won't fit in there. There's always one tool I'm missing.
#24
That sounds like my best plan.
#25
#26
A 21mm long reach closed end wrench with a cheater pipe was able to get those rear UCA axle mount bolts. Just had to work around some brake hose interference, got it done 1/4 turn at a time. Now to tighten up the front.
#27
It may be a good call on the loosening all the control arms. I did a quick rough measurement check and I'm seeing 3.5in gain in the front with my measly 2in Mopar lift with my stock front bumper. I was anticipating about 3in, so should be about perfect once I install my front AEV bumper, 12K winch, and AEV front skid plate.
#29
My toe is definitely messed up with this tie rod.
