Can you use the 32 KM2 Spare with 33's?
Ugh!
Back and forth with deciding between 35's and 33's.
I think I am going to go with 33's and the new Goodyear MTR 305/70/17
Instead of the 35 12.5 17
Does anyone with 33's not get a 33 spare and just use the 32 if needed?
I never put the Spare into rotation so, it would just be there for limping home/getting through the trail if blowing a tire etc.
The rims are kind of driving it, I am going to use the Mopar Steel Grand Cherokee Full Size Spare Rims and have something set up to get 4 new rims.
I'd rather keep the OEM KM2's on the moab wheels. Plus I fab'd a Gerry Can holder and High Lift set up on the stock rear bumper/gate which I would have to scrap that with the extra inch.
I know the ABS will be screwy but, it would be for limp home or go through the trail.
Has anyone run into this before?
Thanks in advance
Thanks in advance
X2. Think if you get a flat on a trail that it took you in several places being locked frt and rear then trying to get out unlocked with a smaller tire. I always try to think worst case scenario.
Sorry to revive an OLD thread. I am curious if anyone has any first hand experience with this? I plan on getting 33" KM2 tires for my Jeep and leave the stock SRA on the spare, so I can cover it. I THINK I have a limited slip rear end, since I can be "tail happy" in the snow with ease.
I just want to know if I can get away with using a 32" spare on my jeep (open front d30) if I get a flat on the highway or something...
I used the stock 29" spare on my old WJ just fine with 31" tires.
Had a flat on a trail. WJ had quadra--drive. The 3 good tires were aired down to 15psi so were more like 30" in height.
Stock I left at full pressure. No problems.
With a locker or limited slip, sure it will be a little funny, but on a budget, to get off a trail or to limp to a station to have the tire fixed, I would have no problems doing this.
On my old ZJ with the NP249 I had the same set up but I had a 30" tire for a spare and 31x10.5 tires. Got a nail in the tire on-road.
I aired the 3 good ones down to 20 psi and put the spare on at full pressure. Drove 50MPH for about 20 minutes to the next gas station and got it fixed.
The NP249 is VERY sensitive and will burn up the viscous coupling with mis-matched tires. I mention this as mine had 130,000 miles and functioned perfectly fine. ZJ was a '94 so it was more biased towards to having the front drive shaft spinning compared with the '96 that were not biased towards the front driveshaft as much.
Just use your head and it's fine as a TEMPORARY solution.
Sure, it is best to have a full size matching spare, but I also understand budget constraints. Do the large size, save up another 2 months and buy the matching spare.
fyi, I carry a tire repair kit now and air compressor. I do about 35,000 miles a year and am often in very remote areas. They area bout $25 for a kit and super easy to use.
But you can always just try it yourself.
Well. I don't hardcore wheel my Jeep, so flat tires would be caused by on road debris. Also, buy 5 tires and having to pay someone to rotate all 5 is a pain. I plan to just cover the 32" and run 4 33s. If I went 35s, then I would have a matching spare for sure.
