Can these 3 items be used together for more lift?
In the rear of my jeep can I use the following 3 pieces together? If so what order should they go in? Thanks
1) factory isolator
2) TERAFLEX guide and spacer (as pictured)
3) and a 3/4" spacer
1) factory isolator
I don't know about all three, but you can certainly use 2 together. I have TF's 1" spacer with guide, under the rear factory isolator. Works perfect. If you'll try all three, IMO I'd go factory isolator, your 3/4 spacer, last the TF with guide.
Rob if you want to go higher get new springs. Do it right. You have adjustable control arms/track bar. Taller springs, make some adjustments and you're done.
