Can someone tell me what this oil leak is coming from?
Old 04-02-2016 | 10:33 AM
blackhawkspkane's Avatar
Default Can someone tell me what this oil leak is coming from?
There is an oil leak not the engine, not the differential. Right after the skid plate. Please let me know what its coming from to fix the leak. Thanks. Click image for larger version
Old 04-02-2016 | 11:28 AM
14Sport's Avatar
Looks to me like the upper oil pan gasket. What year is your Jeep? There was a TSB for 2007-2008 with a timing cover porosity issue that presented itself like it could be the oil pan gasket here.
Old 04-02-2016 | 12:47 PM
it's a 2009 Sahara jku
Old 04-02-2016 | 01:02 PM
14Sport's Avatar
Yeah then my guess is a cracked upper oil pan gasket. That's some nasty looking rust. Was that in salt water or a flood or something?
Old 04-02-2016 | 03:54 PM
Canada salt roads
Old 04-02-2016 | 04:31 PM
14Sport's Avatar
Canada salt roads
Gotcha. You may want to hit it with Salt Away.
Old 04-02-2016 | 06:19 PM
Thanks bud ill give it a try. Probably going to be sandblasting the bottom this summer
Old 04-02-2016 | 07:00 PM
mountain pee's Avatar
I have a 2009 2 door that had/has a leak just like that. It had a little oil on the transmission protection plate. When I removed it, it still looked like it was coming from the oil pan gasket I changed the oil pan gasket this morning. I will let you know if that fixed it in a few days when I know for sure.
Quick Reply: Can someone tell me what this oil leak is coming from?
