Can I swap axles from 2dr to 4dr
Hi All,
Would like some advice on this maybe crazy idea I have. Currently I own an 07 x 2DR with Auto trany and 4.10 gears. I want to purchase an as cheap as possible new 4dr X with Auto but realize I can only get the 3.73 gears. I want to put a small lift... probably 2.5" BB with 35's on it but don't think the 3.73s will push it well here in the northeast.
So here comes the crazy idea... could I simply swap the complete axle assemblies between the two vehicles?? Then I get the 4.10 gears on the 4dr which should push the bigger wheels.
Thanks for any help/thoughts!!
Assuming they are eqquiped the same (both have rear locker or both dont) it is a straight bolt-in swap. Its a lot of work though, why not just have the new one regeared or are you keeping both?
the answer is yes, but like it has been said that is a lot of work removing and mounting 4 axles.... and 4.10s with 35s isn't much better than 3.73s. Reagear to 4.88 or 5.13
Thanks for all the replies. I will be keeping both Jeeps. As for moving them around, I do have a forklift and a very large shop to do the swap in. Well I've got a few more months to think it over. Jeep really needs to start offering taller gears as an option... or a big ass motor!!!
Thanks
Thanks
I would regear that way you're all set if you change your mind later on
But you do what you want and 410 isn't bad if you get 35s but seen a guy with 488 and was sold
But I will be going 513 when I get the green light from the boss
