Can I fit a 33" or 35" spare on Factory spare mount?
Old 10-22-2011 | 06:53 AM
Delawarebluejeep's Avatar
Default Can I fit a 33" or 35" spare on Factory spare mount?
Thinking about picking up either 33's or 35"s. Was wondering if either of these will fit on the factory spare mount, or will I have to get a new rear bumper and spare holder to accommodate the difference in size???
Old 10-22-2011 | 07:02 AM
Robar's Avatar
They will probably fit. The most you would need to fit is a spacer and several companies make them. The problem is the weight. The extra weight of a larger tire often causes damage to the tailgate, over time. The weight + vibrations separate the spot welds on the tailgate.
Old 10-22-2011 | 07:05 AM
GreenJK07's Avatar
Both sizes will fit. You will need a spare tire spacer if you plan on running a 12.5 wide tire, but I would suggest a full size tire carrier. I ran a 35 with the mbrp spacer for about a year. The carrier made awful noise and bent my tailgate out slightly. No major issues but not to my liking.
Old 10-22-2011 | 07:40 AM
robsjeep9's Avatar
JK-Forum Ambassador
I have a Mickey Thompson MTZ
35" x 12.5" tire on the back of mine with a Mickey rim 4.5 backspacing no problems and no spacer needed.
Before that had a 33" Mickey tire/rim 12.5 wide no problem 2yrs.
It will work for a while but eventually will get a tire carrier too.
ID:	226912   Click image for larger version
Old 10-22-2011 | 08:05 AM
Blakspire's Avatar
I run a 35x12.50x17" on my factory mount, with no spacer. Its all in the offset.
FYI I've had zero issues with bending or breaking anything. Almost had it on for two years.
Old 10-22-2011 | 08:16 AM
muddenjeep's Avatar
Recommend teh smittybilt oversize tire carrier, shop around and google search coupons code for websites, i found it for $70 shipped. It gives teh extra support need.
Old 10-22-2011 | 08:19 AM
20JK10's Avatar
I would suggest getting a set of Daystar tailgate bumpstops #KJ09144BK to help keep the tire snug.
Old 10-22-2011 | 09:36 AM
r3cluse's Avatar
I had a spacer with the OEM bumper but don't need it with the Rugged Ridge XHD rear bumper. I have the tire stops but they created a pivot point. I need to find a way to brace the top or bottom. Or break down and finally get a tire carrier.
Old 10-22-2011 | 10:59 AM
Tight_wad's Avatar
If you can Fab/weld then make your own spacer. That way, you can space it out and up the amount that you really need. I have done a couple of them. When I make them, I set it up so that when the gate closes, the tire is actually resting on the tire cut out of the bumper. And as for the rubber spacers, 3/4 heater hose will work. Just shove it inside the original rubber bumpers and cut to length need.
That what I have done. And no issues for 2 years now.
Old 10-22-2011 | 11:05 AM
jeeeep's Avatar
315/70/17 (35) stock carrier, wheels 4.5" backspace, no issues.
fits snug, no spacers/bumpstops needed
