Can I do the Yoke conversion to stock Drive shaft?
Hello,
I am going to get the rear Tera Flex drive shaft with the yoke conversion.
Can I buy the seperate yoke conversion kit for my Stock drive shaft
Front Axle: http://www.quadratec.com/products/52237_000.htm
Tcase : http://www.quadratec.com/products/52237_002.htm
Would changing to these and retaining my brand new front drive shaft make it stronger and more durable on my 4" lift?
Also, Whey does it say that the labor on this is MODERATE? What all does it requre to set it up?
I thought that was wierd b/c the Tera Flex drive shaft with the yokes shows Easy Labor?
The add says it is for the stock drive shaft but just wanna be sure it will fit the Tcase properly and all.
thanks
thanks
