Can 513 gears go in a Dana 30?
#22
#23
#24
Just ordered 5:13s from David with a new carrier , the carrier is only about as much as a tank of gas better to have it then to crack open the diff and realize u needed one, mine will be in the shop this week I let u know how it goes..
#25
yes you can run 5.13s , and yes you can keep the 3.21 carrier if you run thick gears!
#26
Glad to get it from Dynatrac (if anyone should know what works and what doesn't it's them), either way, it's not relevant to the OP as he currently has a carrier for 3.73's, so the carrier isn't the problem.
I'm on the fence between 5.13's and 4.88's when I get my new front d44. I'm leaning towards the 5.13's and sacrificing the gas mileage because i have the 2.72 t-case ratio with an automatic trans, so to get a decent crawl ratio I'm gonna either need 4.88's and a new t-case or keep the t-case I have with 5.13's. Also, I don't typically drive >65 mph during my daily commute, so the higher rpms aren't a real problem for me. Just my .02.
You guys realize that the difference between 5.13's and 4.88's behind an auto is only like 115 RPM at 70 MPH, right?
