cam bolts how do they work
JK-Forum Founder
cam bolts are a cheap fix and one that should not be used on a jeep.
first off, if you have not already installed them, DO NOT INSTALL THEM! cam bolts require you to notch out your control arm mounting holes so that they become rectangular slots. this allows you to shift your axle so that you can have a tiny bit more positive caster up front but, everything is ultimately held together with washers and the tightness of the bolts. for regulars street driving, this is fine but, if you wheel your jeep, the bolts and washers will eventually come loose and that will allow your axle to shift around. fixing this after the fact will require you to have the slots welded up.
JK-Forum Founder
so far as i know, AEV no longer uses cam bolts. regarding their brackets, they work great if you don't plan on playing hard on the rocks or flexing out your jeep. if you do, i would not recommend them as they are not only a BIG rock target, the 2 piece design of them is pretty flimsy and i have seen them bend excessively when flexed out. over time, i fear that this bending back and forth will eventually lead to a failure. i personally would recommend getting adjustable control arms instead. but, that's just me.
I mainly drive on the road with the one or two off roading trips a year (best I can do with my schedule), but I may be headed to the SW for 5-6 months this year and one trip to the San Juan Mountains in August with the Chicagoland guys. I still don't "plan" on rock crawling stuff that Moby can do, but there may be the occasional situation. I'm really caught between OME HD coils/shocks, LCAs, Front DS set up and the AEV set up (had only planned on buying a Front DS if I had to). Thinking AEV's lift and just see how it goes. As one guy once told me, buy to what I'll primarily use something for, not for the exception. Hope that thinking works here!
JK-Forum Founder
Thanks for the tip.
well, if you have your heart set on it, the AEV kit will give you what you want but, if it were me, i would get the rancho sport kit instead. the rancho kit is very similar in design and, it comes with much beefier drop brackets that are welded together and costs a fraction of the price of the AEV kit. if you could see both in person and in action, i can assure you that you would agree with me on this.
Wish I had read this before I installed my RE standard kit this past week. Those tabs were a pain to remove. Oh well whats done is done. I'll know for my next jk, lol
