Is this a cam bolt
On a Jeep, it's a bad thing. Cam bolts don't hold worth a crap on a Jeep that sees any kinda of wheelin action.
This goes back to, You should just save up your money till you have enough to purchase the, ultra super lift kit ,and not just buy what you think you need.
4WPW is sh1t! I would take ti to them and demand they remedy the situation. Check any and all paperwork you have and see if there is anything authorizing them to drill out your CA mounts. THAT IS BS! I'd be Fing POd!
JK-Forum Founder
are you saying that they installed cambolts without asking you first? man, i would be pissed. ![Mad](https://www.jk-forum.com/forums/images/smilies/mad.png)
as mentioned, your lower control arm mounts would have been notched and will need some washers welded in place to make the slots back into holes.
JK-Forum Founder
ummm, no. in order to use cam bolts, you need to knock out the tabs on your lower control arm axle mounts and this effectively makes them into slots. by slotting them, you can push or pull the bottom of your axle forward and back just a bit and enough to offer minor caster adjustment. it would be impossible to set your caster with them if you did not slot your mounting holes. they are blowing smoke up where the sun don't shine.
Yeah, I'd be pissed. Assuming they didn't trick you into signing some sort of permission for them to do cam bolts, I'd demand that they fix it on their dime. Cam bolts had to be the worst thing I ever did for my JK... I can't tell you how glad I am to have it fixed now.
If you went to 4WP in Moore, they suck monkey balls. However, the manager is a real nice and knowledgable guy. His name is Cory. I would go talk to him and tell him this cam-bolt business won't stand - especially since you never told them to do that. That's not what should be included in an alignment.
Because the adjustable lower control arms were on back order when installed my lift, I had to use the cam bolts. Once I got the arms, I no longer needed the cam bolts and accomplished the same castor by lengthening the control arms.
You might want to remove the nut and washer on one and snap a pic, by looking at the pic of the cam bolt installed, with the bolt all the way back, there is little doubt that they had to slot the bracket.
