C Gussetts
Old 10-19-2011, 05:36 PM
cru9's Avatar
Default C Gussetts
What brands do you prefer?
Who had them welded with out taking everything apart?
can you weld them on with the coil spring in place? I was thinking jack jeep up take off tire and keep wet rags in places to help slow heat down..Any input would be helpful
Old 10-19-2011, 05:38 PM
Pothole_Patrol's Avatar
You can weld them with springs in place but be careful With your ball joints.
Old 10-19-2011, 05:39 PM
cru9's Avatar
What do you suggest doing?
Old 10-19-2011, 05:41 PM
bbrown626's Avatar
It only took a couple hours to yank the housing out. I installed sleeves and gussets at once.
I don't see how you can weld them all the way around without at least pulling the spring out. I use mig, not stick.
Old 10-19-2011, 06:26 PM
hagausaf's Avatar
had my sleeves and gussets done at the same time my axles were down for the gear swap. Plus I got heavier duty ball joints installed
Old 10-19-2011, 06:30 PM
Friday2322's Avatar
I had Evo C's put on, just weld slow and take plenty of breaks to cool everything off with wet rags and you'll be fine.
Old 10-19-2011, 06:35 PM
hagausaf's Avatar
oh and forgot, I used EVO C's and Sleeves along with control arm skids
Old 10-19-2011, 06:44 PM
nmwranglerx's Avatar
x2, exactly what I did. Hired a local certified welder. Took tires off but pretty sure I left coils on.
Old 10-19-2011, 06:53 PM
dinojeep's Avatar
I did the EVO Cs. No need to take the springs out or the ball joints, go slow with wet rags as stated above. I also welded on some lower CA skids from EVO at the same time. About an hour for it all.
Old 10-19-2011, 07:00 PM
Merlin4979's Avatar
Got mine at Quadratec, along with LCA skids.
Quick Reply: C Gussetts
