which c-gussets & sleeves to go with??
#31
The front d30 and d44 are basically the same housing. The only real difference is that the 44 has a bigger center section to fit the 44 gearset. The tubes are the same length, diameter, thickness, and they use the same c's.
So any housing upgrade you would want for the 30, you would also want for the 44.
#33
#34
Is it still possible to sleeve the front axle (D44) if it is slightly bent? My camber is slightly off on the passenger side, and it could either be a bent C or bent axle. Not sure how to determine which one is bent.
Planning on installing the Evo C gussets soon, but have not pursued getting sleeves for this reason.
#35
Sponsoring Manufacturer
EVO MFG Representative
The only real way to tell that I know of is to try. Either way it is a good idea to try becuase if your camber is going to change any more, its only going to get worse.
EVO
#36
It really depends how bent your axle is, since you say slightly then the EVO Sleeves will most likely slide in. Out of the many JKs we have installed these in, we have only had one that was too bent. This axle was obviously bent went you looked at it head on.
EVO
EVO
#37
I would gusset/sleeve both and not worry about it again. Just my thoughts.
#38
I am considering sleeving and gusseting as my first real mods. I have the mechanical skills and a welder, so I'll do it myself. I have a couple questions though.
1. Why do some sleeves have a grease fitting and others don't? Do the materials dictate which sleeves require greasing?
2. From what I have read on here and TF instructions, the welding requirements are different (Nr and location of holes). Is one better than the other? TF directions have you drill holes where they can be easily accessed for welding. Using a Mig upside down is not the best position for a quality weld.
Thank you.
Thank you.
