which c-gussets & sleeves to go with??
I was thinking going with EVO mfg c2-gussests to beef my D30. Still not sure if I need to sleeves it. If it's easier to install the sleeves at the same time than welding c-gusset, so I will do it. I found Teraflex gussets and sleeves are the half of the price of the EVO one. Are they equally strong? Did somebody knows other brand than TF & EVO I should consider?
I don't know about the teraflex but me and 3 buddy's of mine have EVO on our Dana 30 and they work great no problems and there known to be much stronger than the other brands. I would go with them but that's my opinion.
Gussets can be welded on without removing anything. Though if they don't take their time and keep it cool, they'll fry your balljoints.
The R-SE Bombshell kit is another option to look at, in addition to the TF and ORE.
You and your buddies only have gussets? Or sleeves as well? And your runnin 35 or 37?
For inner sleeves, the entire axle needs to be disassembled, they drill a bunch of holes in it, clean it out, slide the sleeves in, and weld up all the holes.
do i just just gusset for the moment and do the sleeves and i regear later. Or i can just gusset D30 and regear later without putting sleeves. Plan to ride 35, maybe 37 in the future. Don't plan to do hardcore rockcrawling...
I have the upper and lower C's and sleeves from tf. They're great. I don't think it will really matter what company you go with, I think they're all good. It's a matter of how much you wanna spend. I got my set from ORW and got a sweet deal on them. Much cheaper than the evo's I believe.
My D30 is sleeved and gusseted with EVO. Having the axle sleeved is much more labor intensive than the gussets. I have not had any problems yet. EVO was the only recommendation I received, but I have not heard anything bad about TF.
Ok so what are recommend me. I know you have a lot of knowledge on that.
But assuming you are not planning on a front 44/60 upgrade, consider adding the gussets now, and think about adding sleeves when you have the gears done. One common statement concerning sleeves is "it's cheap insurance". Inner or outer or both (or neither) is your choice, just decide how stout you feel your axle is and go from there.
As far as the brand goes, I don't think you could go wrong with any of them. They will all do the same things, so just shop prices and rear reviews. Some people have even posted about installing the TeraFlex gussets, and having the ORE gussets welded on overtop of them. It's all up to you...
Went on TF website and just saw c-gussets for top of axle. But if GutlessPhred have upper and lower C's, i should be able to find them too. I will go on this way to reinforce my axle just to be sure to avoid problem with the heavy 35 Toyo. Then will see if I sleeve it or not when I will regear. Thanks for comments!
