C -Gussets?
Old 04-17-2012 | 03:17 PM
  #21
robsjeep9's Avatar
JK-Forum Ambassador
Originally Posted by Mudbob
got evo gussets and sleeves on the way. looked like the best ones around and think they build good stuff.
I have the EVO gussets I was just wondering if when welding them on if you can remove the ball joints (instead of keeping them cool with wet rags) and the RE-USE the same BALL JOINTS?
Anyone know? Thx
Old 04-17-2012 | 04:47 PM
  #22
sa29560's Avatar
Hey rob, just from what I have heard and seen, when you press out ball joints it transfers a ton of pressure in the worst direction on the joint.
After being removed, the stock units are done, they are the worst ball joints ever. Even doing the ball joints, gussets, sleeves, and truss on my buddies xj the stress on the joints to pop them out finishes them off. I would not dream of using them again. Best bet, pop old ones out, burn on your steel, paint it up, press in new joints
Old 04-17-2012 | 04:55 PM
  #23
robsjeep9's Avatar
JK-Forum Ambassador
Ok thanks...... now to get a good price on them
Old 04-17-2012 | 05:19 PM
  #24
NightRider08JK's Avatar
Call Sean or Dirk at Northridge4x4. Top notch guys and they will hook you up.
Old 04-17-2012 | 06:25 PM
  #25
superjk10's Avatar
What kind of wire do you guys use to weld em?
Old 04-17-2012 | 06:56 PM
  #26
Inko's Avatar
An ER70-S6 would work for a wire.
Old 04-17-2012 | 08:02 PM
  #27
DanieltheManual's Avatar
Evo. Prep takes the most time, a good welder only needs 30mins to stitch it up. Nice to have skilled friends with their own shop too.
Old 04-17-2012 | 08:12 PM
  #28
sallas's Avatar
It looks like your upper C gussett hasn't been welded at the back to the axle - is this required?
I didn't realize how easy it was to 'pop' the springs out while welding in my gussets at the time. Now knowing better I'm planning on this weekend to weld the back of the upper C gusset to the axle in having clearance to do so by removing the springs - that is if it's worth it?
Old 04-17-2012 | 08:16 PM
  #29
Bosox5's Avatar
got the TF C gussets, nice addition for sure. My C's are bent slightly though after years of wheeling.
Old 04-20-2012 | 07:07 PM
  #30
BlackRockBurner's Avatar
funny, the factory axle c's are solid steel too.
Got me there. Thinking buttress would be easier to wash off mud. I still have baked mud on the cats.
Quick Reply: C -Gussets?
