Busted Yoke-Axle ... It looks painful. Sounds it took.
Nope =( I'm thinking of taking them down to 4wheelparts and have them assemble them because I'm afraid I might jack them up. What do you think? It's doable? or no? I saw some videos of someone using a hammer and a socket... but ... that "nervouses' me"
personal opinion is that if you feel nervous or uncomfortable about doing it, then pay someone who can do it. i have heard of the hammer and socket method, but i am like you with some parts, little nervous to mess something up. maybe someone else can chime in and verify the need for pressing in the u-joint. sometimes spending that little bit extra $$ is worth it
Choices.. choices.. 4 Wheel Parts already got around $1800 bucks from me this past week.. (I bought a winch and a bumper too!)...
http://www.youtube.com/watch?v=g76yO...=88&playnext=2
This guy makes it look really easy.. even though it's a rear drive shaft he's doing..............................
i checked through some of my old posts and the answers i got back then is the u-joint needs to be pressed in.
i believe on older jeeps, the hammer method would work, but does not seem so for the JK. the hammer might work but i would advise against it.
btw, your new axle, is it stock or an aftermarket?
I replaced them with AlloyUSA chromolys. Hopefully they'll last longer with the locker.. the stock driver side lasted about a week after the locker got installed.
sorry can't help past this point
The axles and U-joints aren't a difficult install. I installed the U-joints with a hammer and some sockets as I wanted to know that I could do this on the trail if needed. You can also do this using a bench top vise. I would recommend a heavy duty U-joint. Many people feel that the U-joint should be the weak link, but as you can see when the U-joint fails it takes out the axle and sometimes other stuff as well. Here is the write-up from awhile back.
https://www.jk-forum.com/forums/show...ont+axle+shaft
