Which Bumpstops?
Which Bumpstops?
Looking to upgrade my factory bumpstops on the teraflex bumpstops extensions since it is time to replace/upgrade.
I have narrowed it down to the:
-Kings
-Fox IPF
-Sumosprings
-Run New Stock Bumpstops
Don't want to run the TF SpeedBumps.
Thanks!
-Kings
-Fox IPF
-Sumosprings
Thanks!
might list your build and your intended use. if just running stock and on the street stock is great. If running the baja 1000 or KOH Kings might be best. Stock has worked just fine on my rigs but I am not racing across the desert at mach speed.
^^agree. I can't imagine spending on really nice bumps. I did spend on the MC adjustable rear bumps just cuz I knew I'd be having some changes in the back and would need to adjust my bumps accordingly, but I hated paying $80 for em. I finally just replaced my front hockey pucks with an actual evo bump since my axle was out anyhow. I feel like I wasted $40 in hindsight. Unless you're doing some dessert racing, can't see spending on pricey bumps.
Basically I want to be able to handle desert stuff without bucking like a horse at 40 mph.
I got 3.5 RK Springs, Upgrading to Fox 2.0 shocks and have RK adjustable all around.
Axle wise I got the ultimate offroad dynamics tie rod and draglink with gm 1 ton ends and Artec full armor truss in the front.
