bumpstops
bumpstops
Just a curious question, maybe a dumb one! Have stock bump stops 3" lift with bilsteins 35's . Will smaller bumpstops allow more flex?? Can I cut them?
Former Vendor
If the shocks are made for the 3" lift they'll get damaged at full up travel by bottoming out, you may also have some fender rubbing issues. I would definitely extend the bump stops sooner than later.
From your profile pic, you are running without fenders? Yes, less bumpstop will increase the up-travel, until the point where the shocks over-compress and you destroy them. Run the numbers and see what you come up with, but you are probably better off leaving them as is.
