Bumpers with HiLift holes?
2 reasons we had to get rid of the Hi Lift Jack.. first the jack was mounted on the hood and was becoming extremely heavy for me to lift off without damaging the hood.. and the second reason.. there's no where on the JK that I would deem safe enough for a Hi Lift jack.. plastic bumpers and tin foil body panels.. However, I agree with finding the right bumpers and sliders (not side steps) to use as anchor points if you intend to get and keep a Hi Lift.. Otherwise, I've been using a floor jack.. with "red" points under the jeep to remind those needing to jack the jeep up to mate red on red.. Thou I do miss being able to jack the jeep up from one side and rotating both tires at once..
@JE8154
Hum. is there an issues with (at one time) being able to jack the left or right side of the jeep and rotating the tire (back to front, front to back) all in one swoop?.. never had an issue.. used it for four years like this.. after all it is a "Farm jack" and has a variety of uses.. even sent pics to Hi-Jack showing the many uses.. Mind you this was while drive our late 99.. I wouldn't attempt doing this with the JK.. unless the JK had reinforced bumpers and side rails.. being creative is the order of things in our family and glad you above the custom drop blocks.. can't wait to use them.
