Bumper/Tire carrier
Bumper/Tire carrier
I purchased a PureJeep bumper/tire carrier through northridge4x4. I wasn't going to wright anything do to some issue's I had none having to do with the product.
The bumper and carrier are top quality stuff I must say. Install was a breeze as well. Everything bolted right up. No issue's with anything. Some of the hardware I feel should have been grade 8 I thought. For example. The nuts and bolts they offer to bolt on the actual tire mount were kinda small IMO. I purchased grade 8 nuts and bolts for that only. The bolts they offer to fill in the holes in the bumper if you don't buy the d-ring shackle mounts rust quickly. No big deal. Paint will take care of that. Once everything was mounted and secure, not only worked perfect, I have ZERO rattles. No noise coming from any were. I read about folks having issue's with rattles and noise once the install is done. Not the case with this setup. The setup I purchased was PJ2003
Would I recommend this product, absolutely yes. One other thing. One of the T-handles did not make it into the box when it shipped. Dave talked to them and I had one in my hands within a couple day's. Not sure if it was Dave, or the guy's at PureJeep, maybe both. But I had a replacement part ASAP.
For all you folks having problems with noises and rattles with your NEW bumper/tire carrier, Had you purchased one from PureJeep... you would not have those problems.
thank you Dave (northridge4x4) and PureJeep for great product and service.
I have liked their product, how many miles do you have with the new bumper and have you done much wheelin with it installed? just curious cause I have yet to find a bumper/carrier combo that didnt end up making noise, just curious, thanks
For those of you that have bumper/tire carriers. Have you found the ones that mount to the bumper itself to be much quieter? I had a 91 bronco for a long time and the tire carrier needed new bushings every few months.
