Bumper installation ????????????
I just got my new bumper (SMITTYBILT XRC) and was wondering, can I reuse the factory fog light wiring for new fog lights. for example a set of kc daylights?
You would have to check on the power requirments. I believe most people have had trouble using the factory wiring. But you should be ok if you don't go larger then the wattage of the factory fogs. And it's not the wiring size, rather it's the can bus system seeing to much power being pulled from the lights that makes the computer shut down that circuit.
wow! I didn't think it would be that involved. I thought u just take the factory lights out and put the new ones on. If the new set of lights come with the wiring harness and everything should I use it.
