Bump Stops: Fox IFP or King
Are the Fox IFP bump stops better than the King bump stops? Is the tech inside of the Fox IFP stops better than what's inside of the Kings? I'm trying to figure out what makes the Fox IFP stops more expensive than the Kings. Any opinions would be appreciated. I'm about to invest in front and rear.
The fox have an internal floating piston (IFP) that separates the oil from the nitrogen. It something nice if you are desert racing but totally not needed for 99.9% of JK's Fox just knows if you make it for a JK some idiot will buy them and bolt it on their rig. If you don't understand what an IFP is then you really don't need it.
So then should I just get the regular Fox 2.0 bump stops? They are significantly less, like $400 for front and rear. Kings are about $600 for front and rear, but then I just noticed that King also makes a hydraulic bump stop for about $1100 for front and rear.
I don't know where I should spend my money.
