Bump stops
The generic response would be 2" as 35" tires are roughly 2" taller above the hub then factory. You might double check the collapsed length of the new shocks compared to the factory ones but I doubt they are more then 2" longer.
For that kit- absolutely check it before you drill or order anything. After you receive your new parts, check again to ensure that the bumpstops are going to contact the pads on the jeep- before you drill where RK says to drill.
