Bump Stops
Cool.
Disconnected, with 3.75" of lift, short 35's (33.5" actual), 2" front lower stops, and cut stock flares, I have a bit less than 1" between the tires and flares. Without the 2" bumpstops, the coils are fully compressed and the tires are rubbing the chopped flares.
Another hi-jack here
Hey planman I have a teraflex 2.5 coil lift, was planning on adding 1in. spacers, cutting my stock fenders and running toyo 37 in tires on rims with a 4.5 or less back space. Will I need more than the bumpstops that I have with my lift now. I'm planning on new 1350 driveshafts, 5.38 gears, all eight control arms etc. and maybe 1in. body lift if needed. Any thoughts or should I just go with a 4in lift and skip the spacers and body lift?
Wow...I have a bigger headache than when I started...
I gues 2" bumpstops (front and rear) will be good...Someone please correct me if I am wrong.
This is what I am planning...Will I be OK??
08 Rubicon
Procomp wheels (4 3/4 backspacing)
2.5" RC coil lift
Bushwacker Flat Flares
315/70/17 (35" or so) GY Duratracs
2" front lower terraflex bumpstops
2" rear lower RC bumpstops
08 Rubicon
2.5" RC coil lift
Is there a write up on adjusting the steering stops??
In case anyone needs them, I found this deal on ebay for 2" Rubicon Express front lower bump stops. They are only $12.79 shipped!! These are like $40 regularly. The ebay item # is 390285905420 and there is one set left (already got mine)...BTW, this is not my ebay item and I dont know the seller...I just bought them and fig I would share the deal with the forum
so i just got my 35s put on with my 2.5 rc lift and my rock sliders are where i am rubbing... a little on the flare but flatties are on their way... has anyone had to cut the rock sliders down a little?
