bump stops
bump stops
what bump stop is everyone running, im adding the 3.5 rock krawler x facter kit. does anyone have experice with the daystar evs bump stops?
thanks guys
thanks guys
Sponsoring Manufacturer
I'm running these on mine. They can really help smooth things when you hit dips/bumps at speed or when you have alot of weight in the JK.
http://www.teraflex.biz/products/jk-...-3-4-lift.html
TeraFlex SpeedBumps have the following features: • JK Specific tuned for high speed performance • Simple installation - no welding required • Quiet movement & function (no pad-slap clunk) • Absorbs large impact energy progressively during compression to prevent bent axle tubes • Maintenance free, all-composite construction • Resistant to all types of conditions (mud, salt, sand, dust, etc.) • Compatible with all suspension systems that retain factory axle & spring mounting locations • High compression rate with full memory rebound • Engineered for maximum lifetime compression cycle • Unsurpassed dynamic performance • Maximum low temperature flexibility reduces fatigue & premature failure in subzero conditions • Limited lifetime Warranty • Made in the USA • Patent Pending technology
JK-Forum Founder
most lift kits come with bumpstop extensions as they are needed to help prevent the over compression of your coils. does the rk kit not come with bump stop extensions? if not, a bump stop extension is a bump stop extension and you have lots of options available to you. the only thing i would recommend is that for the front, you get the kind that bolts up to your axle and not extend from the factory bump stop location.
i am running the 3.5" kit also and i got the jks adjustable bump stops for the front.
http://www.northridge4x4.com/proddet...?prod=JKS-1100
and i got the teraflex rear lower bump stops
http://www.northridge4x4.com/proddet...rod=TF-1954700
I do still some minor rubbing in front and rear but its not anything i am worried about. I plan on getting rid of the stock flares some day soon.
