Bump Stop
Bump Stop
why do my bump stops rub my springs in the front... the springs look to be set properly... my axle is centered... ???????? its annoying.... anyone else having this issue if so how did you fix it... thanks
If they are rubbing on the same sides (i.e. left side of both springs) then an adjustable track bar would fix it. If it is because the springs are bowing then you would want to try to reseat the springs.
i have an adjustable track bar and its centered perfect... its rubbing on the inside closest to the motor on both sides... my springs don't look bent maybe a little... it doesn't make sense to me... are the springs hard to remove i have never done it before...
