Building custom tube fenders for my unlimited
Hmmm..... I may be able to reproduce a set
I kept all the measurements and templates and probably have enough material to make one more set. The EVO ones are $899 per front and another $899 per rear (and I think more for skins and powdercoat) and I am not sure I could produce them for less than that with my time in it etc...
Shipping would be a bear too!
They look great! Good job, you've got great fab'n skilz! Just keep in mind when you lean on a rock or graze a tree it will bend your sheet metal. If you look at EVO's they started off like yours and now it covers the whole side of the the fenders. Other companies haven't produced them because of the same issue. Plastic ones like xenon don't look as good as yours but when they hit a rock or tree they will flex and bend, less likely to damage sheet metal.
I had the xenons and they do bounce back... usually... but once you wack'em they are never straight again and they do tweak the body.
I ended up skinning the back like the evo's there just isn't a way around it.
The front however... If you install a good rocker you don't need to skin them. (skinning them is in fact easier than tying them into the frame which is probably why evo went that direction) My tubes are also tied into the frame (or sub frame) at 2 points... THEY ARE SUPER TOUGH. They are tough enough to use as a jack point. So I would need to REALLY crank something to do damage. If I hit anything that hard I guarantee the jeep would be mangled with a flexible fender!!!
And the tubes aren't as strong as the frame so the tube will give in a huge hit before the frame gives. Make sense?!
Last weekend I took a slow rollover on my side and the fender isn't as much as waved from the impact... The rear that stillhas a xenon on it, well, that is a different story!!!
