Build Dana 30 or Atlas???
#21
#23
#24
If you don't like noise from your drivetrain work on the axle or get a rubi case. The atlas uses gears instead of a chain for drive and is a bit noisy with the front axles turning all the time. I would suggest you look into an axle that has locking hubs before running an atlas. Other then that I see no reason not to run the atlas case if you have the money to buy one. Some people think the 10.3:1 gear ratio is just not needed and I agree it is not everyday you use it but it is nice to have that super slow ratio on very hard technical climbs. It is nice to have the choices of that may gear ratios.
#25
is your tcase recommendation implying that the atlas is overkill for a 44? what about a 2-speed? I was in Moab with the stock 2.72 tcase, wishing I could crawl slower and wondering if the 4:1 would be slow enough. just curious on your thoughts behind your recommendation. cheers.
#29
Forum Tech Advisor
