Build 1 tons? Or buy dana ultimate 60s?
#21
I agree with Dr. Dirty. I'm at about $10K in my Kingpin and 14B. Shit adds up real quick. Not sure why you want to cut corners and not go the extra mile and build it right. Hate to have to get into it again later. I was already into my build when the UD60's came out, otherwise i would've gone that direction. But I'm not regretting my build.
I did the entire swap in 2 months with over 300+ shop hours logged. A offroad shop would easily charge you $5000-$8000 in labor for such a job. Want plug and play? Buy the UD60's and enjoy the jeep days later. But you're still going to be spending upwards of $13,000-$15,000 for axles, driveshafts, misc parts, labor, tires, possibly wheels. There's a lot of factors that go into play with a 1ton swap. Sounds like it's time for you to research the process the same way we all did and do the math. In the end, the only thing the equation doesn't take into consideration is your need to have it done now, versus learning how to do the work yourself. Having someone install the hardware for your doesn't teach you how to pack bearings, bleed brakes, setup pinion angles, measure caster, break down 1ton calipers, install driveshafts, change diff fluid, removing 1ton axle shafts, working on a full float 14b. So while that investment for UD60's sounds great, you may very well be paying people to do maintenance on them for years to come or taking the time to learn how to do all of the same work required to do a 1ton axle swap with a D60/14b setup. The stealership charges $135 a differential to change fluid.. Installing axle seals is another $200.
The biggest perk for me on the swap is all of my parts are located at the nearest Autozone/Napa/Advance Auto. I can find axle shafts and parts in just about every Pull-A-Part from east to west coast. My brake calipers for my D60 were $25 a piece
#22
There's really only one thing to have to consider in this entire discussion, do you want it done now or can it be a project that sits in the garage a few weeks while you spend time doing the work, drinking beer and jamming out to some music? My neighbors hate me yes, but the end result is nothing short of beautiful. It's mine, I did the work and when someone looks underneath to see the 1tons, I'm able to have a full discussion as to how I did the swap, why I did particular things, answer questions from others looking to do the same and then go wheel the hell out of it. This is the shit they don't tell you at the dealership about "Jeep Life"..
#24
I ended up going with VKS rings because my hubs were strange and wouldnt work with artec. I installed 2 sensors on each rear tone ring. Works fine but I dont drive it on the street.
#25
Tweak provided you the pictures from his older 14b. I was fortunate to have the converted 14b that came factory with disk brakes. This was a double edge sword honestly. Tweaks work is based on the earlier 14b and it wasn't until later in the game after waiting for the release of the Artec swap hardware, that he realized he wasted valuable time on something that wasn't going to work. So before you dig deep into it, make the experience better by getting the correct 14b so that you don't accidentally become a test case in the matter lol.
To answer your question, we ran the wheel speed sensors to the rear 14b. Artec makes the mounts that actually bolt up allowing you to run dual sensors on the rear tone ring. Very easily accomplished. Just make sure to get good clean connections and make sure the sensor is index correctly. If the sensor is too far away from the tone ring, the system throws codes. I soldered up about 20ft of 16ga wire and wrapped it in heat shield down the passenger side of the jeep. I left plenty of extra to make sure I could run it safely to the sensors and give enough length for articulation to prevent breaking a connection.
#26
I just started my 1 ton build after 3 months of reading and seeing what was best. I got a 14 bolt from a 03 Chevy and d60 from a 05. Ill be doing all the work myself and my friend will do the gears. In all That I have put in shopping carts I look to spend about 7500 or so. I'm in no rush and I plan on being done by next year better than having to save 13k for axles to spend at once I can just do a lil here at there. Since you won't be doing your own work. It makes no point in doing it. You'll end up spending more than just buying.
